2018 Z71 113k miles.
Runs flawless as long as it doesn’t rain or I go through a car wash.
If I ride through a car wash, P00CA
If it rains, I can sometimes back out of my driveway and the code appears or I can drive it a couple miles, hit a puddle or heavy rain and it’s immediate.
I know about everything under the intake, just don’t see how that could be my issue because there’s no way moisture would make its way in there as quickly as it happens in the rain.
i did pack one plug under the truck with dialectic grease on the Fuel lines hoping that was my issue, but it didn’t work…
any ideas?
  • 5 months later...
FINALLY! Someone with the same problem as me. Mine is a 2017 Z71. Runs perfectly...until it rains. "Engine Power reduced" message comes on the dash. Check engine and traction control lights come on.
  • 5 months later...
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
