1 minute ago, Phillip Larson said:
I miss my Sierra classic crew cab. Is it worth it to take an old truck with close to 300k miles and put a new vortec 5.3 engine in it, new transmission etc, to make it like new?
Depends on your skill level. Early in our business career in the early 80s during the winter rain out. We refreshed two mid 70s Ford Crew Cabs. Luckily we each had different skill sets to make the refresh easier. We did it in my yard, we didn’t have our shop yet. We took everything off but the cabs. Pulling the engines and transmissions. We had Chilton manuals to aid us. We sent the engines and transmissions to researched rebuilders built to our specks. New front end parts, rustproofing, brakes and lines. Fuel tanks and lines. We painted parts and pieces instead of together to lessen mistakes. Not only did we work those trucks pulling equipment. They carried born free campers across country. We drove those two fords and two 83 little Toyota trucks for ten additional years before replacing with diesels one by one. Honestly the Toyota’s never needed anything. Not an easy ride either going up and down pipelines. The best part they weren’t stock. And a blast to drive.
If it's worth it to you, yes. At 300 K, not me.
Edited by diyer2
Depends on the condition of the carcass to me. Does the project truck have good bones? Is it new enough that parts sourcing won't be an issue? Do you enjoy such projects?
You can replace the entire driveline and most or all of the suspension with NEW for a FRACTION of the cost of a new truck and in the end you have a new truck. That is IF the rest of the truck, body, chassis and interior are is really good shape.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
