Hey, have a 18 Chevy 1500.  Wondering if I buy a AC Delco stability switch control with 7 various switches (currently 2 switches), can the other switches work if I also buy a GM Upfitter Junction Block Connector Aux Switches.
Thank You,
James Beyer
