On 5/10/2023 at 3:50 PM, gjrobinson68 said:
I had the same issue, I ended up buying an aftermarket fin type antenna from Amazon (image attached), removed the interior electronics, drilled a hole for the camera and mounted the camera in the housing.  Then mounted the fin on top of the cap and used the cable listed below (Amazon).  It took a couple of tries get the angle right (used silicone to glue the camera into the housing) but it works well for me, less than $50 including painting it to match my truck and a few hours DIY time.
My dad has my truck for the next couple of weeks, I will post a picture when he gets back.
I would love to see your install if you can post some pics.  Did you use the original camera or leave factory in place and buy an aftermarket?  If you used factory, did you need to seal up any holes or gaps once the factory camera was removed?  Also curious as to how easy or hard it is to located the cable in the cab headliner.  Again, thanks for the info and sharing your solution.
On 2/20/2023 at 10:30 AM, CameraSource said:
We have a simple solution that just about anyone with basic mechanical skills can install.  It comes with a factory GM camera, extension cable, and a small fully adjustable bracket assembly that allows you to attach the camera onto the third brake light of your topper. Check it out here:
https://www.camerasource.com/factory-digital-mirror-camera-relocation-housing-kit-for-2019-2023-gm-trucks
We have a universal style kit that can be mounted on any flat surface, i.e. doesn't require a third brake light for mounting.  This model will be great for people with drop in campers etc.  https://www.camerasource.com/factory-digital-mirror-camera-universal-relocation-kit-for-2019-23-gm-trucks-camera-included?q=cs-3gm
If you have questions please call 888-844-9763 as we do not frequently monitor private messages on this forum!
Camera source, do you have a toggle for this to keep the original camera and an add on? I want to be able to remove the topper and revert back to stock without having to drop the headliner.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
