Hi Folks,
Does my engine sound normal? I notice there’s some ticking noise at startup, and it goes away in 1 minute or so. Thanks!
Edited by Justin Jia
Grammar
Sounds normal to me.  They are known for piston slap on start up.  Might change brands of oil, not viscosity, and see if that clears up the noise.  It did for me when I switched off regular Mobil One for ACDelco's oil.
  • Thanks 1
Thanks!  I’ll try and see if it makes a difference.
Kinda sounds like a minor exhaust leak but hard to say for sure. Broken exhaust manifold bolts are fairly common on these trucks. Possible that it's a lifter too, that as well is a pretty normal LS engine noise to hear.
  • Thanks 1
Normal, assuming you have no broken manifold bolts.
#PIP5104B: Cold Engine Tick Noise That May Last Up To 50 Seconds - (Feb 9, 2016)
Quote
Models:  2009-2013 Cadillac Escalade Models
2009-2015 Chevrolet Express, Silverado, Suburban
2009-2015 GMC Savana, Sierra, Yukon, Yukon XL
With any of the following V8 Engine RPO Codes: 6.0L - L76, L96, LC8, LY6, 6.2L- L94 L9H
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
You may have a vehicle with a concern of cold engine tick noise.
This concern will diminish within 50 seconds of a cold start.
The noise shuts off like you have flipped a switch.
This concern may be a vehicle design characteristic as the ECM calibration is designed to meet cold start emissions.
The noise that you hear is actually combustion taking place in the exhaust manifold. When the timer hits the 50 seconds it advances the timing and the noise is immediately gone.
Recommendation/Instructions
Be sure to determine if the tick noise is possibly coming from the exhaust manifold, as this noise could easily be mistaken for an engine tick noise.
If your SI diagnosis does not isolate the cause of this concern, and all of the following statements apply, this concern should be considered a vehicle design characteristic of the ECM calibration and no additional repairs should be performed:
  1. The concern has been present since the vehicle was new.
  2. The concern is greatly improved or eliminated if the engine is allowed to warm up for 1 minute.
  3. The concern is present on a similarly equipped vehicle.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Edited by newdude
  • Thanks 1
THANK YOU! Your information is VERY HELPFUL!
I think the noise is from the exhaust manifold! I’ll double check!
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,734 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
