GM Headlight Switch
USED OEM HEADLIGHT SWITCH FOR GM 2014-2019 SILVERADO/SIERRA,  SWITCH INCLUDES OPTIONS FOR FOG AND AUX DRIVING LIGHTS.  THIS IS THE SWITCH EVERYONE IS UTILIZING TO UPGRADE FROM THE OEM ORIGINAL FACTORY INSTALLED SWITCH WHEN ADDING A LIGHT BAR OR ADDITIONAL LED'S.  THE BACKLIGHT COLOR OF THE SWITCH IS BLUE AND MATHCES THE REST OF THE LIGHTS IN THE CLUSTER AND DASH CONTROLS.
SWITCH IS USED AND FULLY OPERATIONAL/NO BOX.
$20.00 plus Shipping
Interested.  Mine has the fog light switch but being able to add aux lights seems to be a plus.
How hard is it to tie into the aux ?
I assume it would be plug and play with the existing fog lights.
It isn't hard, there is an additional wiring harness that is needed from Gamboa that connects the BCM to the light switch.
The switch has been sold.  Thank you for everyone's interest.
  • Sad 1
  • 3 months later...
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
