Hey all. Seeking some help on what appears to be some driveline vibration. 2019 Silverado LT Double Cab. 2” level front level. I attempted to install 1” rear blocks to get some rake back. Had some bad vibration and immediately uninstalled the blocks. Torqued everything back to spec, but the vibration has remained at highway speed or when accelerating over 2,000 rpm. The truck does have the factory shims. Anyone have any input on what might be causing the issue or your operating angles for reference?
Check your driveline angles as well as rear axle alignment.  Most vibrations of that nature are results of driveline angles.
This is certainly not what we like to hear, Rhaboush.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 Silverado LT Double Cab. To do so, please send an email to [email protected] with ATTN: Rhaboush/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
