Hi,
This question is for a 2022 Silverado LT (refreshed interior) with a 5.3 L V8.
I am getting ready to run some 10 gauge red/black zip cord through the firewall on the passenger side and connect it to the battery.  This is my first experience with a vehicle with a Battery Management System.  I will be connecting the red part of the cable directly to the positive post of the battery, but I am unsure if I should connect the black wire directly to the negative battery terminal without going through the current sensor, or should I run the black lead through the sensor ring?
At most, the transceiver would be running 100 watts output and according to the radio manufacturer, the radio pulls about 22 amps when it is putting 100 watts RF into the antenna.
Thanks!
If it were mine, I'd run the current through the sensor, just so the ECU knows how much is being used so that it can charge the battery accordingly. From my experience it seems they put fuel mileage as a priority over battery life. I'd personally prefer that reversed, but this is the world we live in. That's my reasoning for going through the sensor - the battery is going to need all the help it can get to make it just 6 years (When they used to last 8-10 on average without electronics).
Thanks!  And I do hear you on the battery life!
Appreciate the input!
Here is an article that may be useful for your project in case you haven't seen it already.
http://www.k0bg.com/wiring.html
Here is one sentence that is  in the article.
It is imperative that the ELD not be bypassed when wiring amateur radio equipment, so typical wiring recommendations found in Owner's Manuals should not be followed!
Edited by Duelin
A double copy of the posted link
FYI Duelin, I got a 404 on that link.
Ahh, I see what happened - the link got posted twice right next to each, so it's trying to go to the double address.
What an excellent article!! Thanks, Duelin!
Edited by Jsdirt
Thanks.  Very familiar with k0bg's website, although I admit it has been a while since i perused it.
Again, thanks for the input and the referral to refresh my brain cells!
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
