My brother, A., is a new mechanic, and he recently bought a 2000 Chevy Blazer 4x4. I registered an account on this forum to post the following on his behalf. Any help would be greatly appreciated, as he has tried everything he can think of to remove the stuck oil pan (he needs to remove it and replace it, as it has a crack in it):
Quote
my engine oil pan wont come out i took out all the bolts there were 9 bolts holding it down 3 bolts on the bottom of the bell housing and 2 grommets with 2 nuts and i pulled them out and the pan went halfway down and wont come out nothing in the service manual google or youtube nothing anywhere i dont know how to get it out
Thank you!
   Guarantee those clips holdine the lines in running beside oil pan on passenger side is your karma for it not dropping. Make sure. You definitely got all bolts, clips lose, then take a heavy rubber mallet and give it a few knocks. Those clips are still attacked to either the pan, or the mount above, they will hender pan dropping.
unbolt the oilpump and it will come off providing you have the clearance between the frame and the engine. do you have the engine jacked up for clearance? if not you may have to unbolt the mounts and jack lt up and stick blocks under the motor mounts
52 minutes ago, Jenn Foreacre said:
i removed the bolts and clip on the side of the pan from transmission cooler line and starter shim the only thing i could think is the oil pick up tube
Make sure the oil filter holder is not also a problem. Sometimes those are put in a position where it impeeds the pan from coming off. Otherwise, take a 1 inch putty knife, and see if ut just make be old and cousing it to not drop all the way. I have dealt with it b4. Simply an old compressed oil pan gasket.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 556 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
