Anyone have a console they’d be interested in selling or potentially trading for a jump seat?
2016 GMC Sierra SLT with the tan/cocoa interior. Would like to have a console to replace the jump seat with.
Located in AL.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
