2011 Silverado 1500 LT 4x4 - 114K miles 5.3L - AFM disabled
took a 5 hour trip north pulling 26' travel trailer and all was fine.  2 week vacation with normal drive, all fine.  Left for home yesterday and 1/2 way thru the trip home stopped to get gas, about an hour later stopped at rest area and when deceling the truck sounds like it was exhaust braking (BOP BOP BOP BOP).  Stopped truck - used rest room, came back and truck fired right up but had a rough idle and a rough acceleration.   once about 25mph or so, truck ran fine.  no power loss and no change in gas mileage/performance.  experienced this rough idle behavior the last hour trip home.  after parking trailer, i checked for codes - and none, none stored and none pending.  no lights either.  truck still drove the same after dropping off trailer.
this morning, fired right up - and 30 seconds later, flashing CEL and Service Stabilitrak.   left truck at home and drove wifes car.  i plan on checking for a loose spark plug wire when i get home.  any other thoughts on what to look for?
I didnt have time to check codes before work this morning so i will when i get home.  with in the last year i have all new plugs, wires and coil paks.  can you all give me some other ideas before I take it to my mechanic?
The flashing CEL means theres a misfire, Scan to see which cylinder(s) ands start diagnostics there
i hope its an easy fix.  I have had a cylinder #7 misfire (3 years ago) and that plug was oil fouled.  i replaced all the plugs and never had an issue since.  i also at that point disabled the AFM.  When i had the original misfire, i never had the stabilitrak message.  what makes that  message appear with a mis-fire?
Edited by Bleepster
Solved.  #4 spark plug boot was slipped off.  Whew.  Easy fix.   Purring like a kitten now
thanks
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,858 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
