I'm looking for is something that will hold charging cables inside of the grooves that let the cable exit the bench seat console into the cabin where my phone is.  I want this so that it will keep my center console neat and may increase the lifespan of the cable.
I want to pose this question for the forum since I'm sure a solution is out there, but I've looked at Amazon, Home Depot, and Walmart and I can't find anything that I like.
I've attached a screenshot of where I'm looking to secure the charging cables for reference.  The cable clip (or other solution) would need to be equal to or less than 1/2 an inch wide and 5/8ths of an inch tall.
Foam tape? High density 1/2" thick could stick to the bottom and you could cut a slit from the top for the cords to go through. Cheap, replaceable. I might try it.
Edit: Google or Amazon search cable clips. Many options and ideas.
Edited by Rock
additional info
16 hours ago, discgolf01 said:
Exactly what I ended up doing, only I put them on the outside. Inside could also work though.
I ended up finding a solution to my issue so I wanted to share my results.  I wanted a cable clip that would fit inside the channel and would allow me to add or remove a cable from the top.  I was able to find a cable clip which would do this when mounted on the side.
Here's the product I used: https://smile.amazon.com/dp/B09CMMQ7V2?psc=1&ref=ppx_yo2ov_dt_b_product_details
Thanks everyone for the suggestions!
Heck, that's perfect! Nice find.
What are you going to do with the other 28?
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 776 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
