Wiring Diagram
Chad H
Hey guys,
Does anybody have a wiring diagram for a remote start going on a 2004. I presume its the same for '03. I need the power, start, ign 1, ign 2, acc wires. Also, what are the wires for the security bypass. I hope somebody can help me with this. If i have those wires I can do this for sure. :seeya:
  • 1 month later...
I just put a remote start in my '03 Sierra Denali and my cousins '03 Silverado last weekend. Bulldog list the wiring as the same for '03 and '04 Silverados as follows:
http://bulldogsecurity.com/New%20Wires/New...evsilv03-04.htm
2003-2004
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED (x2) IGNITION SWITCH HARNESS
IGNITION 1 PINK IGNITION SWITCH HARNESS
IGNITION 2 WHITE IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 1 ORANGE IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 BROWN IGNITION SWITCH HARNESS
STARTER YELLOW IGNITION SWITCH HARNESS
KEYSENSE LT. GREEN ( - ) IGNITION SWITCH HARNESS
PARKING LIGHTS ( + ) BROWN ( do not use ) *SEE NOTES BELOW* 1
PARKING LIGHTS ( - ) GRAY/BLACK BROWN PLUG pin B2 @ BCM *SEE DIAGRAM*
DOMELIGHT ( - ) GRAY/BLACK (L), BLACK/WHITE ® EACH DOOR MODULE in DOOR *2
DOMELIGHT SUPERVISION USE DOMELIGHT WIRES
POWER DOOR LOCK LT. BLUE ( -) LT. BLUE PLUG @ BCM *3
POWER DOOR UNLOCK WHITE ( - ) ( TYPE B) with FACTORY KEYLESS *SEE DIAGRAM* *5
TACH SENSOR WHITE (AC) INSTRUMENT CLUSTER or PCM *4
BRAKE WHITE ( + ) AT BRAKE SWITCH
HORN BLACK ( - ) or BLACK/YELLOW @ STEERING COLUMN
FACTORY DISARM LT. GREEN (-) DRIVER DOOR MODULE in DOOR
FACTORY ANTI-THEFT TYPE PASSLOCK II
NOTES:
*1 - The BCM is located behind the drivers side of the dash.
*2 - On BASE model trucks the door trigger wires are in the LT.BLUE plug @ BCM, pins B4 and A5. On 4 door trucks the LR door trigger wire is LT. BLUE/BLACK, pin A3, the RR is LT. GREEN/BLACK, pin A2. They are in the PURPLE plug at the BCM. Use all wires and diode isolate.
*3 - On BASE model trucks the lock wire is LT. BLUE ( - ) and the unlock wire is WHITE ( - ). They are in the LT. BLUE plug at the BCM.
*4 - The PCM (Power Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the GREEN plug, pin 10. For tach you can also go to any of the ignition coils and use the wire that is NOT PINK, BLACK or BROWN. Wait-to-Start wire is BLUE in instrument cluster or PCM.
*5 - At the BCM in the purple plug, look at row B, cavity two and three should be open with not wires in then. If you make connectors for these pins you can connect them as a( TYPE B ) door locking system.
Don't use the Bulldog Passlock 2 bypass module-it's way more work to install than most of the others. For most of the others all you do is provide CONST 12+, GRND, splice 1 wired into the OBDII connector and one out to the remote start bypass wire. I used the Bulldog 791 and it was alot more work and there is all kind of conflicting information about how it was supposed to be wired up. We wanted to beable to use the factory fob so we had to fish a wire into the driver door to catch the lock wire(light tan wire on the latching plug). Anyway, good luck with your install. It was the first remote start I've done and it ended up being easier than I expected.
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,692 Guests (See full list)
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
