Hello all!
I am looking at getting a used set of rims for my truck so I can swap between winters and non-winters easier. My current rim size on my 2015 silverado 1500 is 18 inch (tire size is 265/65). I have an opportunity to get a set of 17 inch stock rims with 255/70 tires on them. Wondering if the rims/tires from the 2018 will work without issues on my 2015? They are so close in overall size I don't suspect there will be an issue but just want to be sure.
Thank you!
