Search on Google. There are many videos that will take you step by step through the process.
I set my lock unlock with the DIC, but wondering if there is an option to unlock both doors with one RKE push, the last couple vehicles I have owned allowed this, but so far haven't found any way to accomplish.  2007 2500 HD. LT trim
1999-2002 I don't think you can.  2003-2007 have the ability to change the settings as they added the DIC with settings to configure.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,225 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
