Does anyone have a link to the passenger side battery distribution block diagram? I have a 2020 High Country Duramax 6.6. I am specifically looking for where the 100a fuse goes to. I accidentally blew that fuse, and can't find any info online about what is connected to it. I have the wire pulled off of that fuse in the Pic.
Edited by Gunnar Jacobson
Did you look on the inside of the fuse block cover?  I can’t remember if there is a diagram or list but there may be one there.
I'm a fan of the electrical diagrams from the GM Upfitters website. You can get it at https://www.gmupfitter.com/light-duty-vehicles/light-duty-2020/. It's in the electrical section on page 218.
Pretty sure there's some typo's on the diagram though. It has F4 through F8 in the wrong order. You can tell because F7 and F8 are definitely not 125A or 150A fuses. From what I can tell, your blown 100A fuse goes to "E40 Electrical Axuiliary Heater (C32)".
Does that whole bussbar need replaced when 1 of those fuses blow? Looks like the fuses are riveted to the bar.
That’s what I have read, yes. The angled crimp connections are specific to GMs design. You could replace a fuse yourself, but it seems the GM intent is to replace the whole unit if one fuse is burned out.
@Random...
What does the schematic say the 5 amp fuse is for? Strange seeing it with the size of fuses it is hanging out with!
31 minutes ago, gemarsh said:
@Random...
Says it goes to "K9 Body Control Module". I'd think the BCM would need more than a 5A fuse, but I didn't look anymore into it.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,066 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
