At idle there is a chirping noise coming from the bell housing area. Has anyone else had this problem and if so what is and what is the fix for it?
Edited by Gary L.S.
  • Gary L.S. changed the title to 2017 Silverado 4x4 chirping noise
My 15 does this only at an idle. If I barely press the gas it stops. I have no clue what it is. Mostly after it's warmed up and notice it when idling when in park. But will also do it if idling in drive like at a drive thru.
14 hours ago, Gary L.S. said:
The chirping noise is coming from in the bell housing it sounds like. Where is the solenoid at you are talking about?
It’s somewhere in that area.
I have a 2017 SLT Crew 4x4 with the 6.2. I had a weird noise like that. And it would do it getting back onto the throttle while rolling even. I even had the dealer check it out. They couldn't figure anything out other than possibly a rock on top of a shield. They would've had to charge me to pull it off to check, so I said I'd just do it myself. While I was under the truck rock hunting, I saw the goofy valve behind the muffler. I had been searching forums, and it kept coming up as a source of weird noises. I chose to ignore that since mine was from the bellhousing area. I couldn't find any rocks, so I thought what the heck and found a drywall screw to screw into it temporarily to hold it open. Low and behold, the sounds went away and so did the clang during cold start during cooler weather.. I guess that was valve slamming open. Anyway, I took it and got that thing cut off.. I haven't had any weird sounds since.
There is a plastic shield at the starter than will intermittently drag on the flywheel. About a $9 part that cost a bit more to replace. They warp sometimes. Just a thought.
