Ive got a 2014 silverado 1500 and since i bought it the throttle had been weird. To start its very unresponsive or unsensitive sometimes it seems i gotta have it floored to get enough power out of it to even pass someone. The other thing I've noticed is it seem the rpms kind of stick so if im siting and i rev it the rpms go up but then it almost stays high and comes back down really slow when i let off the throttle. Just wondering if something may be wrong if this is normal or if there's something i can do to improve it.
What motor?
have you pulled the air box and looked at the throttle body to see if it's loaded up with oil from the evap system and is jamming up the blade a little? Also look at the Mass Air Flow sensor to see that it's not filthy too.
Something the 14's and above had is that they are drive by wire and if you watch carefully the gas pedal will have a bit of a dead zone because the pedal is not tightly bolted to the firewall and the bottom area of the pedal on the firewall will give way as you depress the pedal. My fix was to use rubber paddles from my old snowblower to wedge behind the pedal and against the firewall. That problem would only be noticed when you slightly tap the gas you will have a bit of a dead spot before the RPM reacts to you pressing the gas.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
