Searched all over, can't find a definitive spec. Anyone know the bolt torque spec for the rear differential cover bolts? I have the SU7, 9.5 AAM axle. Truck is a 2022 LTD Custom w/ 2.7T
I am wanting to do a differential fluid service today and noticed the rear diff has no drain plug, so I have to remove the cover to drain out the oil.
Thanks in advance!
Edited by fondupot
1 hour ago, fondupot said:
Searched all over, can't find a definitive spec. Anyone know the bolt torque spec for the rear differential cover bolts? I have the GU6, 9.5 AAM axle. Truck is a 2022 LTD Custom w/ 2.7T
Thanks in advance!
Believe it or not, makes a difference on the manufacturer of the axle.
GM uses both AAM axles GM manufactured axles.  This started with the beginning of the T1XX trucks in 2019.
You will have to scan the QR code in the door or have the dealer run the build on it and look for RPO code SU7 (AAM) or SU8 (GM).
SU7 axles, the cover bolts spec is:
First Pass: 15 lb ft
Final Pass: 20 degrees
SU8 axles, the cover bolts spec is:  30 lb ft
Both require new thread locking compound applied to the bolts.  High strength high temp red.  Gasket is also one time use now unlike 14-18 trucks.
  • Thanks 1
Thanks I have the RPO sheet my truck has the SU7 rear axle with GU6 3.42 ratio. I mixed up the RPO codes. I ended up buying a service manual so I was able to find the specs and procedure. Thanks for your help!
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
