Hello all,
I wanted to see if anyone else has this issue and/or knows how to fix it. When playing a video, the voice is delayed by about a second or two and is not synced. I've done google searches and nothing I've tried seems to work. Any idea? It's a 2022 Sierra Denali
Thanks much!
Edited by rackt09
  • rackt09 changed the title to Audio/Video sync issue - Android Auto
Hello all! This is certainly not what we like to hear. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your trucks. To do so, please send an email to [email protected] with ATTN: [Forum Username]/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
