Vehicle:  2020 Chevy Silverado TB LT
Objective:  Install ARB Air Compressor in truck using GM Upfitter Switches
I get around, a lot.  Offroading, driving on beach, desert cruising, camping, hunting, etc.  I also stop and help people that are stuck in the middle of the road.  Basically, I use my truck to do truck things.  Whether it's for myself where I need to adjust air pressure in the tires, or to help somebody with a flat tire, I want to install a small air compressor in the bed of my truck.  I'm looking specifically at ARB air compressors because of their popularity, compact size, and commercial support.  I want to power switch to be switch #5 on the GM Upfitter switches, which I already have installed.  I am aware this switch is already pre-wired for a rooftop light, but I don't have a rooftop light and believe I can just spice right into it.  I also like switch #5 because it's on a 30 Amp fuse.  I was hoping to go with ARB's twin compressor (CKMTA12), but looking at the spec sheet (attached) I don't believe this is a good idea because it's too much of a load.  This caused me to start looking at their next compressor down, the CKMA12, which is a single version.  The amperage seems to be just below the threshold of the fuse for switch #5 until it gets to 100% load.  Given that I won't be using the air compressor for air tools because everything I own is battery-powered, and I only see myself using it to fill tires (and maybe the occasional air mattress for camping or kid's floaty for a day at the beach, is it okay to go with the CKMA12, or is it too much of a load?  Am I completely mistaken about the CKMTA12, and it's okay to use?
I'm not proficient in electrical matters.  I can do the install so long as it's plug and play, and maybe a splice or 2.  I can create basic harnesses with Deutsche and weatherpack connectors, so long as they don't have relays, etc.  But there's definitely a knowledge gap on my end beyond those abilities.  Advice and input is greatly appreciated.  Thank you in advance.
There is a relay in that circuit already but where it is only a 30a  circuit I would just create a new circuit with the correct gauge wire , fuse and relay to handle the desired load. you could still use that switch to control the circuit as the switch just delivers the ground to activate the relay. A relay is basically just an electrically controlled switch so that you are not running high current through the manual switch and can keep the high current circuit more direct. For the larger compressor you may want to run a constant duty solenoid vs a relay due to the high load and an under hood circuit breaker
Edited by richard wysong
  • Thanks 2
Thank you for your reply.  I read it a few days ago and had to stew over it to fully grasp what you were saying.  Like I said, "I'm not proficient in electrical matters".  Sounds like it will be easier for me to just use the ARB wiring harness and install directly to the vehicle battery and pace the switch in the truck bed near the compressor.  In that regard I'll just go with the twin setup.  I was planning on installing rock lights and chase lights to switch #4 of the upfitter switches, but I guess I'll just do rock lights on switch #4 and chase lights on switch #5.
Thank you very much for your input.  It is greatly appreciated.
    RyGuy43
    RyGuy43
  • Who's Online   3 Members, 1 Anonymous, 535 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
