'19 High Country, radio stations song/artist does not display? Radio stations I listen to, do display the info, my old '06 H2 would have info displayed.
Any info?!
FM radio stations does not display "Artist/Song titles" on my 2019 Chevy Silverado 1500 High Country. The radio stations I listen to, in my area, do display their info.
Depends on the radio station. Not all fm channels provide digital song info with their broadcast signal. On the flip side your truck may not have HD radio receiver with that capability.
Edited by jaxcam02
Typically a radio station thing.  Some just broadcast the name, some have the name and the song name.
Don't think its an issue on the truck though.
Radio Data System (RDS)
If equipped, RDS features are available for use only on FM stations that broadcast RDS information. With RDS, the radio can:
Group stations by Category (i.e., Program Type) such as Rock, Jazz, Classical, etc.
Display messages from radio stations.
This system relies on receiving specific information from these stations and only works when the information is available. It is possible that a radio station could broadcast incorrect information that causes the radio features to work improperly. If this happens, contact the radio station.
When information is broadcast from a RDS station, the station name or call letters display on the audio screen. Radio text supporting the currently playing broadcast may also appear.
Edited by newdude
The radio stations I listen to ,in my area do display their info, my '06 Chrysler 300 & '06 H2 radios all display RDS "Artist/Song titles"... Im wondering if it's the radio malfunction in my truck?!
My '19 H/C does have HD radio, I'm wondering if it's a malfunction in my radio?
Alright, so I had a durr moment last night.  Check your settings for RDS in the radio.  It can be turned on or off.
Go to SETTINGS, go to the APPS tab, then open AUDIO.  Scroll down and you should see RDS with a little box to the right of it.  If its on, it will be GREEN.  If its off, it will be GRAYED OUT.
Edited by newdude
I did check, mine is Turn on/green, still no "Artist/Song titles"... Thnx for info tho 👊
  • 1 year later...
Did you ever find an answer? My 2025 is the same way.  If I go to my work truck sitting next to it, I get song and artist, but mine just gives me the radio station line for the same station. It's been around a long while. Please don't tell me they left this capability out.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,196 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
