2004 1500 Crew Cabs are hitting the lots
Where is this happening? I ordered my 04 Crew Cab Z-71 at the first of the month and it took the factory 1 1/2 weeks to accept a sold order. Yesterday (1/28) GM and Chevy Customer Assistance told me that the Target Production Date on mine was 2/9. If they can't do it any faster than this, then Ford is going to eat them alive again this year. I'm on my 2nd Ext. Cab Z-71 since 2/00. One 99 and one 02. One top of the long wait, pricing wasn't even available at the time of order and to my knowledge is still not available at the dealer level. I estimate the one I ordered to be in the $38,000 MSRP range.
LAROCHE CHEVROLET-CADILLAC, INC.
900 HWY 290 W, BRENHAM, TX 77833-5422
GM BuyPower Manager: John Trostle (979) 836-6666 Map
Your Vehicle: 2004 Silverado 1500 Crew Cab Z71 4WD
VIN: 2GCEK13T841277310
Exterior: Silver Birch Metallic
Interior: Dark Charcoal Interior Trim
MSRP:* $38,318.00
See Current Offers on This Vehicle
Contact your GM BuyPower Manager, John Trostle.
*Manufacturer Suggested Retail Price. Tax, title and license fee extra. Dealer Prices may vary.
Window Sticker Division of General Motors Corporation
SILVERADO 1500 4WD CREW CAB Z71
VORTEC 5300 V8 SFI GAS ENGINE
4-SPD AUTOMATIC TRANSMISSION
SILVER BIRCH METALLIC
DARK CHARCOAL INTERIOR TRIM
MANUFACTURER'S SUGGESTED RETAIL PRICE
STANDARD VEHICLE PRICE $ 34,190.00
Options installed by Manufacturer
AM/FM STEREO W/6-DISC CD
CHANGER & BOSE SPEAKER SYSTEM
$ 695.00
Z71 CONVENIENCE PACKAGE 1
6-WAY POWER BUCKET SEAT
AIR COND, DUAL ZONE AUTO
ONSTAR SYSTEM
INCLUDES 1 YR SAFE & SOUND
REDUNDANT RADIO CONTROLS
$ 2,050.00
OSRV MIRROR W/DRIVER SIDE AUTO
DIMMING, PWR FOLD & ADJ,
HEAT, TURN SIGNAL
$ 213.00
SPARE TIRE LOCK
$ 15.00
Z71 OFF ROAD PACKAGE INCLUDES:
DUAL PWR HEATED OSRV MIRRORS
REAR WINDOW DEFOGGER
DEEP TINT GLASS
OFF-ROAD SUSPENSION
HIGH CAPACITY AIR CLEANER
OFF ROAD - SKID PLATES
AUTOTRAC TRANSFER CASE
LOCKING REAR DIFFERENTIAL
FRONT FOG LAMPS
AM/FM STEREO W/CD & CASSETTE
17 ALUMINUM WHEELS
WHEEL FLARES
POWER LOCKS & WINDOWS
REMOTE KEYLESS ENTRY WITH
CONTENT THEFT ALARM
ISRV MIRROR W/COMPASS &TEMP
LEATHER WRAPPED STEERING WHL
BODY SIDE MOLDINGS
$ 0.00
HD TRAILERING EQUIPMENT
$ 305.00
7000 LBS GVW RATING
NO CHARGE
REAR AXLE - 3.73 RATIO
NO CHARGE
TOTAL OPTIONS $ 3,278.00
TOTAL VEHICLE & OPTIONS $ 37,468.00
DESTINATION CHARGE $ 850.00
TOTAL VEHICLE PRICE* $38,318.00
STANDARD EQUIPMENT
Items Featured Below are included at NO EXTRA CHARGE in the Standard Vehicle Price Shown at Right
*** MECHANICAL ***
• INDEPENDENT FRONT SUSPENSION
• MULTI-LEAF REAR SPRINGS
• STAINLESS STEEL EXHAUST
• PLATINUM TIP SPARK PLUGS
• SYNTHETIC REAR AXLE FLUID
• TRAILERING WIRE HARNESS
*** SAFETY & SECURITY ***
• 4-WHEEL ABS W/DYNAMIC REAR
PROPORTIONING
• 4-WHEEL DISC BRAKES
• DRIVER/RIGHT FRT PASSENGER
AIR BAGS
• THEFT DETERRENT IGNITION
• DAYTIME RUNNING LAMPS
• ADJ. RR SEAT HEAD RESTRAINTS
*** EXTERIOR ***
• CHROME FRONT BUMPER
• CHROME REAR BUMPER
• WIDE ACCESS REAR DOORS
• FRONT RECOVERY HOOKS
*** INTERIOR ***
• DUAL ZONE AIRCONDITIONING
• COMFORTABLE REAR SEAT ANGLE
• DRIVER INFORMATION CENTER
• INTERMITTENT WIPERS
• GAGE PACKAGE WITH TACHOMETER
• TILT WHEEL
• ELECTRONIC SPEED CONTROL
*** OTHER ***
• BATTERY RUN DOWN PROTECTION
• OIL LIFE MONITORING SYSTEM
• 24 HOUR ROADSIDE ASSISTANCE
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
