Does anyone know what the factory tint % is on the 2024 GM truck rear door windows? I want to match the front to it and would like to know what tint to use. Thanks
There should be a label on the bottom corner of the glass with the tint level (transparency %). In this example, Transparency of 70% equates to 30% tint.
Edited by Brummie99
clarification
I will certainly check that out. Thanks for the information!
