2020 Silverado active shutter communication lost. Causes the Engine light to come on and won't allow for remote start. Had this repaired once already at the dealer. Thus is getting stupid. Why does the shutter control module keep shorting out? I'm not paying another $200.00 for another shutter assembly. Help!!
Check the wiring for the shutter.  There is a couple spots where they rub through where they pass through the front support.  Lots of sharp edges.  Wiring I think runs down the driver's side.
Could also be a wiring issue in the engine harness which these trucks are known for.
If that shutter was replaced recently, the part itself would still be under warranty for 2 years/unlimited miles from its install date, even if you are out of bumper to bumper.
Edited by newdude
There was a recall for the wiring on certain trucks as well due to improper routing of the shutter wiring causing it to rub through and short out.
Here's the article I remembered:  https://gmauthority.com/blog/2022/07/chevy-silverado-gets-service-update-for-aero-shutter-wiring-harness-issue/
Affected vehicles:
  • 2022 Chevy Silverado 1500
  • 2022 Chevy Silverado 1500 Limited
Number of affected vehicles: GM did not specify how many vehicles are affected by this particular problem.
Owners should: GM will likely notify owners of affected vehicles and instruct them to make an appointment with their dealer. Owners that are unsure whether or not their vehicle is affected by this service bulletin can reach out to GM directly with any questions or concerns they may have using the Service Update number and contact information included below.
Contacts:
  • Service Update number: N222365750
  • Chevrolet Customer Service: 1-800-222-1020
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
