I don't agree with what GM said, apparently this is a feature, and that any other vehicle driving over that road would do the same thing.   I think they just dont want to fix it.  I've never experienced any shaking like that in a vehicle before.
Normal or not, I think the mirror design on this generation is pretty bad (as well as ugly).
On 9/11/2024 at 5:33 AM, CAF64 said:
GM refused to fix this, and said it was a normal feature of the tuck.
Just an update- I had my truck in for service and noted to the service manager that the mirror seems really loose. It is being replaced under warranty. I suggest that you try another dealership.
On 11/29/2023 at 6:11 PM, MesaRat said:
my driver's side mirror is shaking and rattling so bad i think the mirror is going to come off when i hit minor-medium bumps and shakes and rattles moderately on small bumps/imperfections, mostly on maintained dirt road but sometimes on pavement.  i talked with the service manager and showed him a video, and he said it's normal.  he has a 2022 and it does it.  they did say they will look at it but i don't expect anything.
Passenger side mirror is solid.  My 2020 would do it on rare occasion and only with a significant bump.
GM reached out to me a while ago, as result of a survey I responded to, and asked me to send a copy of the video to them.  haven't heard back.
That is not true I have a 2024 sierra 2500 drivers mirror has been replaced 3 times and I'm bringing it back again. My passenger mirror has a little movement, it doesn't shake when going over bumps.
We are sorry to hear of this driver side mirror concern you are experiencing with your 2024 Sierra and would like to investigate this further on our end. When you can, please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to your response.
I hit a railway crossing @ a much higher speed than I normally would. Yes it did shake. I crossed another crossing @ a more moderate speed & there wasn't any movement.
I wonder if it was mounted rigidly, it might cause damage to the cameras during impacts?
My 2024 is on it's third driver's side mirror. The dealer will not try to tighten anything they just replace it.
The passenger side mirror on mine pops and sometimes fails to fully extend/retract. Also shakes quite a bit when it's extended, like previously described in this thread it acts like it's out of its track and/or stripped. I can reset it but that doesn't last for long. The drivers side one does not (yet) give issues. Very irritating, especially at highway speed. Disappointing as the truck only has about 24,000 miles on it.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 0 Anonymous, 691 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
