2022 Chevy Silverado LT with 3" level causing surround view, trailer, parking grid cameras to malfunction, not calibrate correctly
We put 35" Maxxis tires with 22" Fuel wheels on my 2022 Silverado LT with the new, refreshed dash. This required a 3" front and 1" back level. We started having issues with the cameras calibrating after about 6 months. Basically, the system can't calibrate the distance properly so it gives you an hourglass in the upper left hand corner of the screen showing the system is "working", a nice throwback to the microsoft busy icon . This leaves you with no grid lines for parking and no trailer assist. The dealership replaced the front camera and recalibrated the cameras. After working for two weeks, the issues started up again.
Email from GM engineer to dealership stated that the software only allows for 2" of extra distance over stock ride height for the cameras to calibrate so there was nothing we could do and would be left with a dysfunctional system.
There are new Black Widow package trucks out there with a 6" lift that have zero camera issues. The reason why is that Black Widow had to develop their own software in coordination with GM to overcome this seemingly simple issue. GM knows their trucks are going to be lifted. They even offer the 2" lift from the factory on some of the packages. So why not just include this extra distance to compensate for this in the software instead of pissing off people who paid for and really just want their truck to function properly. Black Widow won't sell the software and GM won't offer it as a patch. So, in order for your Silverado/Sierra to function properly, you need the $20k black widow package...
A bigger issue I see is the safety of the vehicle. Should I trust the adaptive cruise and lane keep assist to work properly if the software doesn't even know how to calculate the distance for some parking grid lines?
Does anyone know of software out there that has been developed by third parties to overcome the camera calibration issue?
IMG_2625.HEIC IMG_1366.HEIC IMG_1420.HEIC
Edited by 2022LT
Unless you can find a company that knows how to do it your SOL. GM isn't going to spend the man hours and costs with doing calibrations for every possible combination of lifts and levels.
There isn't an infinite number of combinations required, it is a static distance from the ground to the cameras. It is an algorithm to calculate the distance and compensate for additional height.
GM won't be of any help here as they don't offer calibrations that comply with aftermarket modifications.  None of the issues you are having should even be covered under warranty either because of the aftermarket modifications and the dealer should have stopped right then and there when you pulled up.  Mods that are not GM that cause issue are grounds for warranty block.
The only compliant lift that GM can help with is the factory Trail Boss lift kit as it has authorizations for camera calibrations.
The other problem you are facing is the tire diameter.  The assist systems are dependent on the proper tire size based on the calibrations in the systems.  GM only has calibrations for factory tire sizes and the new trucks on GM Global B are very sensitive to this.
TLDR:  Remove the lift.  Problem solved.
Edited by newdude
  • 3 weeks later...
It's more complicated than that but you are kind of right.
It's really only X,Y,Z, roll, pitch, yaw that can be tweaked and likely it's just the Z to adjust on some of the cameras (not equally but close) but GM and their software will not let anyone touch these directly, like ever.
Actually I'll be damned, someone actually offers a service to reprogram your VPM.
I imagine they could tweak these settings.
Not cheap but probably not many options for this niche.
https://www.whiteautoandmedia.com/product/t1-pickup-vpm-programming/
Edited by matt99199
  • 1 month later...
We'll take a look at that. This is the refreshed dash with the new layout so it's hard to find anyone that is doing any software mods. Hoping to find a fix so we can get everything working as it should.
  • 5 months later...
Hello I currently have the same issue i put a 8 inch suspension 22 rims whit 37 tires and I guess i have to release the its not gonna get fix it? Have you find how to fix yours?
Modifications on current model trucks have way more factors to consider than before.
While I understand the issue I cant see how its GM's problem when something is modified beyond their design parameters ?   Its not 1978 anymore.  GM is hypersensitive to modifications causing warranty claims, dont expect that to change.
    MASONV88888888
    MASONV88888888
  • Who's Online   0 Members, 0 Anonymous, 1,661 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
