LowUfo Posted December 15, 2023 Posted December 15, 2023 I have a 2023 Sierra Elevation. I am replacing the Bose premium speakers. I went with JL audio for front and rear doors. For the dash speakers, I am using Pioneer TSA-709 2.75" speakers. They come with an in-line high pass filter (850 Hz and higher is the pass-through value). Now, when using my Android Samsung S23 Ultra phone - I cannot hear any voices from the Nav or phone calls. Before I take the dash apart - would removing the in-line high pass filter fix the problem of not hearing Nav voice or phone call voices? Thank you
LowUfo Posted December 15, 2023 Author Posted December 15, 2023 Got the answer! Remove the high pass filter if you use the Pioneer TSA-709 2.75" speakers. Just finished. Blinkers work perfect. Phone works perfect. Speakers are great! 2
Mshawn Posted December 16, 2023 Posted December 16, 2023 8 hours ago, LowUfo said: I have a 2023 Sierra Elevation. I am replacing the Bose premium speakers. I went with JL audio for front and rear doors. For the dash speakers, I am using Pioneer TSA-709 2.75" speakers. They come with an in-line high pass filter (850 Hz and higher is the pass-through value). Now, when using my Android Samsung S23 Ultra phone - I cannot hear any voices from the Nav or phone calls. Before I take the dash apart - would removing the in-line high pass filter fix the problem of not hearing Nav voice or phone call voices? Thank you Take out the online crossover on the dash speakers and you should be fine. I have the same speaker in the dash as your and I didn’t use the crossover or bypass and they work fine. 1
Mshawn Posted December 16, 2023 Posted December 16, 2023 Take the in line cross over out and you will be fine . I have the same speakers in my dash I didn’t use the crossovers and it works great 1
LowUfo Posted December 16, 2023 Author Posted December 16, 2023 15 hours ago, Mshawn said: Take the in line cross over out and you will be fine . I have the same speakers in my dash I didn’t use the crossovers and it works great Works perfect !
Mshawn Posted December 16, 2023 Posted December 16, 2023 4 hours ago, LowUfo said: Works perfect ! Awesome I’m please to hear it!!! 1
acmech87 Posted March 27, 2024 Posted March 27, 2024 I'm about to do this exact install on my 2020. Good to know about the high pass filter removal. My question is did you use the wires right there in the dash or did you you run new wires and splice into the door speaker siring? I read some comments on a youtube video that said you get better sound if you tap into the door speakers.
Vincej138 Posted March 28, 2024 Posted March 28, 2024 18 hours ago, acmech87 said: I'm about to do this exact install on my 2020. Good to know about the high pass filter removal. My question is did you use the wires right there in the dash or did you you run new wires and splice into the door speaker siring? I read some comments on a youtube video that said you get better sound if you tap into the door speakers. I used dash wires and it sounds so much better. Not necessary IMO 1 1
acmech87 Posted March 29, 2024 Posted March 29, 2024 On 3/28/2024 at 12:10 PM, Vincej138 said: I used dash wires and it sounds so much better. Not necessary IMO Awesome, thanks.
Register a new accountSign in
