Am I the only one or is nobody paying attention to the possibility of their rear window leaking? My 2019 Silverado had the dreaded rear window leak and when I bought this 2024 Silverado CC I just figured that GM had corrected the problem but nope, it is leaking almost exactly the same pattern as the 2019. Everybody should start looking at the inside back glass of there Silverado or Sierra, the inside glass leaves a tell tale sign if it is leaking.
I guess you're not paying attention to the multiple threads on this:
GETGONE,
I guess maybe you did not read my topic, I knew the earlier models had problems, I went through it with my 2019. But I thought maybe GM had fixed the problem, but my 2024 Silverado is a leaking and I had not seen any post of newer models leaking
You think GM did anything to fix a known issue? I have noticed a LOT more higher trim models having solid rear windows. When I was looking in 20-21 at trucks nearly EVERY LT and above trim had a slider on it.
    MASONV88888888
    MASONV88888888
  • Who's Online   0 Members, 0 Anonymous, 1,677 Guests (See full list)
    • I have 2 choices.
