Thanks for responding. I have sealed everything i can find on the internet and still water dripped in after alot of rain last night. It no more than 1oz eater ever but just cant seem to track it down and the hole looks too specific to not have a need.
I have sealed 3rd brake light and was replaced when i bought truck due to leak.
Sealed the shark fin antenna
sealed the hvac access panel with very strong sealant and then covered with gorilla tape just in case.
And only the front passenger is wet, and water only drips out of that hole. If my truck is level no problem but i park on a steep incline.
My cowl is a bit wavy but I had my windshield replace and leak test just to rule it out.
I also had the dealer replace blower motor about 6 months ago due to it seizing up and breaking.
I want to just seal the hole and then hopefully it will drain out into engine bay out ac drain but not sure what is behind and dont want to flood a bunch of electronics.
Heat blows hot, and A/C blows cold.
and again no water anywhere but the passenger footwell and I can only visibly see water dripping out of the hole.
Im about to lose my mind as im in pnw and it rains alot and has been slowely happening for awhile now.
Almost ready to drop it off at the dealer and push the liabilty on to them and let them track the leak down.
You may have to do what the guy in one thread of search did and remove the passenger fender. That will give you great access to everything on passenger side that could be involved.
