I own a 2007 silverado 2500 (new style) has a 6.0L gas engine.
  I'm having trouble with the heat. It gets warm but never hot like it should be.
I have flushed the coolant and the core 3 times, changed the blend door actuator and the thermostat.
  I can hear the actuator turning as I adjust the climate knob till about 1/2way onto the hot side then the motor seems to stop making a noise. (I suspect something maybe be blocking the actuator inside the vents?)
  When the air is in recirculation setting it warms up rapidly (1min or so) and works as it should. When changed back to outdoor air it cools back down.
Not sure where to go from here, any help would be appreciated thank you!
are the heater hoses about the same temp? if so the core is clear and it is probably a blend door issue, if 1 is cooler than the other the core still has a blockage and if reverse flushing it doesn't clear it it will need to be replaced. It is also possible to have a blockage on the engine side of the heater hoses
Edited by richard wysong
Yes both hoses are the same temperature. (Has been flushed for good measure 3 times)
The blend door actuator has been changed and the issue still persists.
 Could be debris in the box preventing it from closing off the evaporator. Unfortunately there is no easy way to clean it out. Maybe a borescope will help you determine whats going on
Will give the borescope a try. Thanks for the reply.
7 hours ago, davester said:
If you remove the actuator, you can manually rotate the post for the door and see how it feels when you move it to it's limits.
 Yes I have, it "feels" fine but is difficult to tell.
 When I turn it to the max there isn't any difference in heat. Remains the same Luke warm temperature.
If you manually force the door to each extreme, and the air is cool one way, and only warm the other way, when the engine is hot, that points towards the heater core not doing a good job, either because the interior of the core is plugged, or the fins are.
I've flushed 3 times till water was clear, both hoses are the same temperature going into the heater core.
Thanks for the help
1 hour ago, Will Hayes said:
Sounds like I will have to change the heater core. Thanks
In either case, a more thorough inspection inside.
If it gets nice and hot on the recirculation setting, then cools off when switching back to allow outside air in - I would try to watch the door movements to confirm they are doing what they should.
Seems like I remember something about the actuators needing the limits programmed too, but I don't recall the specifics...
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 485 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
