My 2020 Colorado makes a clunking noise in the rear axle which a couple of dealers say is normal. Anyone else having this issue and is there a fix? I was told it is normal but wonder what issues will come later.
Bring this to the dealer.  Rear Axle Clunk Sound – TechLink (gm-techlink.com)
Also bring up bulletin 17-NA-394 and 20-NA-156 that are referenced in that link.
If everything measures in spec based on those documents, there is nothing wrong with your truck.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
