Did you use LED roof lights? They draw less amps.
Yes I did, factory ones. They keep blowing 10amp fuses in the add a circuit. But the strange thing is, it keeps blowing the fuse for 42, so I lose all of my marker lights on the truck but the roof lights stay on. What size fuse should I be using? The factory is 10amp for RH markers.
1 minute ago, Naughty Donkey Performance said:
So, the add a fuse needs to be installed so that the original fuse is still primary and the "add a fuse" is secondary in the circuit, is that how you have it plugged in?
I believe so, I used a 10amp fuse to replace the factory fuse in 42 and a 10amp fuse for the roof lights in the add a circuit.
I have the factory LED lights on mine.  Connected to the "park lights" .  Something like a 5 Amp fuse.  No problems
Yes.  The "add a fuse" is a smaller amperage that the original fuse, so it will blow first if there is a problem  (no problems at all)
