Anyone know a way to pull out a dent in the grill? I was told by a dealer that the front speaker is all one unit, grill and all, but not sure about that.
Pop the door panel loose from just the bottom and reach in there and push it back out.
The speaker is not mounted to it.
Thank you.
So, dealer was wrong, as usual, huh? When you say pop it loose, how to do that? My suburban had screws, so you removed them and lifted the whole panel off, which is why I ask.
Edit: Just found a video. Seems simple enough. Any tips on connectors on the back of the panel if I have to remove the panel entirely to pound the dent out?
Edited by MrLeadFoot
I have fixed those before by getting a fishhook and bending the hook a little so I could get the hook in and the other end out of a grill hole at the dent but clip the point sharp end off so you don't ram it in your finger and start gently pull the dent out, worked great everytime. Our pop the door panel off and do it that way. I tried to avoid pulling the panel off cause sometimes I broke a clip on the panel.
Front doors have two screws along the bottom and two screws in the little hand cubby on the arm rest.
Once the screws are out, start tugging outward starting at the bottom edge near where the speaker is. Once you get to the top of the panel, lift out and up so you don't bend the lock lever. You'll need to undo the door handle cable which will make sense once you see it and the wiring harness. The wiring harness has a clip that also acts as a lever, so once you disengage it, the connectors separate by themselves.
You can then do whatever you want with the door panel, including hammering out the dents from the rear side.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,251 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
