I am still struggling trying to diagnose a problem with my trailer brake controller. My post is long, but I'm hoping someone with more knowledge than me might be able to deduce what is going on.  I have read about the issues with 2024 trucks when connected to a trailer with solar.  That sure sounds similar to what I've been experiencing, but doesn't seem like it applies to older trucks.  So I'm starting this thread from scratch.
Very sporadically while towing an RV I get the message "Check trailer wiring" followed immediately by "Trailer brakes connected". Sometimes it doesn't happen for a copulation hundred miles, and then will happen repeatedly ten times in a row before stopping again.
Twice I've gotten a message saying "Service trailer brake system". When this battlements I lose the trailer brakes entirely and find that the fuse for the trailer brakes is blown. I replace the fuse and everything works again for awhile.
I towed a different trailer that did not have trailer brakes and with that one I got the "Check trailer wiring" message and found that I had lost the rear running lights and side marker lights. After unplugging, reconnecting and restarting the truck they were back on.
I have replaced the trailer brake controller located above the spare tire and also the trailer connector plug in on the truck.
My truck is a 2021 GMC Sierra 2500 HD.
I'm at a loss on what to try next or how to diagnose this.  Any help is appreciated!
  • 8 months later...
I had forgotten about this post from last spring and thought I would post a follow-up for anyone who might come across it.  My trailer brake issue turned out to be a problem with a worn wire inside the axle on the trailer, and nothing to do with the truck itself. Intermittent wiring problems are so tough to diagnose and track down, so we were trying as many different things as we could come up with. Wish we had guessed right in the first place, but happy to have finally figured it out.
I got rid of my electric brakes, but before I did,  I was close to being proactive and doing homeruns for the wires from each wheel to a junction box. The way trailer manufacturers daisy chain the brake wires just sucks to troubleshoot. You can do a resistance measurement and get a somewhat good idea if all the magnets are in the chain but way easier if you can take one off at a time at a junction box.
Edited by bruceb58
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
