Has anyone attempted this yet or have any insight before I just start buying parts and trying this. I have a 2020 Silverado 2500HD LTZ I have hades the chrome grill since the day I got it but never wanted to do the high country grill cause I hate it has high country written in it. Also not a big fan of the new style headlights but I love the lower models like the paint matched Customs and would really like to swap that grill and new bumper on mine
Have you thought about just de-chroming the front end of your truck.  You can easily buy the black LTZ grille and used painted bumpers to get color matched.
I did the process on my LT heavy chrome to a LTZ no chrome,  I even replaced the scopp.  Here is the before and after less the scoop.
You'd need more than the grille.
Yeah I know I’ll need lower valance(below the grill and wraps around headlights, grill, bumper assembly, and possibly a new plastic piece that holds the grill and headlights. Mine currently has the active aero stuff that the original grill mounts too and I haven’t been able to confirm wether the new grill will mount to it or if they sell one for other grill
On 4/25/2024 at 12:12 PM, Cracksrubi said:
I have and honestly I hate the Chevrolet grill if the made a replacement grill that was just a bow tie I’d get it and paint match it and the bumper
Go with the High Country Grille  image.thumb.png.bd1757caaf8a2f9036f8eab8428eebc0.png
I'm in the process of swapping to High Country Grille myself.  It's at the body shop now getting color matched.  They are filling in the High Country letters and then it's getting coated in Bodylliner color matched so it will hopefully not get all chipped up.  Just a thought since you mentioned not liking the words High Country on it (neither did I).
When it is all complete, please post some pictures.  I am not a chrome guy at all either.
Quote
Sorry to thread jack but pic attached of current set up with vinyl wrapped grille to hold me over until my other HC grille gets painted.  The vinyl wrapped one doesn't look bad, but if you walk up to it you can see seams where they spliced the vinyl in places.
Looks great,  make sure you post the final pictures.  You should add the Chevy light up bowtie to round it out.  Have few questions.
How are the rim overlays holding up and what did you the front maker lights up with?
Edited by KTDanforth
Quote
wheel overlays have held up great for the past 2 years.  I'm getting ready to swap to a set of 6 spoke oem wheels from the previous gen body style though powdercoated gunmetal grey.
The markers are tinted with 3M tint film.  I just cut out 2 pieces to fit over the markers.  The curve at front edge didn't turn out as good as I'd like so really need to redo them sometime.
Looks Good
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
