Bought new in 2006, has lived outside almost its entire life.  Roof has what I assume is UV damage, hood has a ton of star cracking going on also.  The rest of the paint is actually really good.  I'm sure many on this forum have seen similar.  I got a reputable local painter's quote at $1200 to replace and paint the hood and the roof they said can be a can of worms job and they're too busy to mess with it.  My question here is what can I do to simply and cheaply seal off the two small rust spots (not even dime sized) and perhaps re-seal the roof to stop the spread of the damage?  Since the hood could be easily replaced later I probably won't do anything with it until much later.
Go on YouTube and watch vicegrip garage. Early this week he was addressing a similar problem on a recent jeep purchase. It actually came out pretty good.
The "can of worms" and "too busy" sounds to me like he just doesn't want to do it.   I have a family owned, as-honest-as-they-come body shop that does my work.  They would never tell me that; they'd just quote the price and do it, and the color matches every time I've had to use them.  I hope someone can tell you how seal it off.
Find another paint shop to do it. Those two things can easily be done by a good body shop.
I'm a huge VGG fan and just came back here after watching that video!  Perfect timing!  Now just to find the right rattle can.  I was also thinking I could use part of the inside of the bed to test out the technique first.
Edited by impala454
I wouldn’t be afraid to try it before doing something else.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
