Recently purchased a 2018 3500 HD and on the way home a service trailer brakes message came on along with ABS light. There was no trailer being towed. It eventually went away as the drive continued.  After arriving home I plugged in my horse trailer to check everything and the left trailer blinker would not work and then I received messages of service trailer brakes and check trailer connection.
No issues with this trailer and my 2012 3500.
I checked fuses and saw that the 12-volt auxiliary was missing a fuse and corrected that. I ohmed out all of the other fuses associated with a trailer.  I disconnected the connection at the rear of the truck that supplies signal to the bumper and in bed outlets. I got a very weak voltage reading on the left blinker so the issue stems from that point forward.  With random messages and funny acting lights, I have read in numerous forums that it's the BCM. Can anyone please advise?
i would buy a scanner that can clear the codes first. the bcm seem to save resistive settings of the  lights
clearing codes even if there isn't any seems to reset the system
Got it scanned and a code for RR wheel sensor appeared.  A mechanic said that it alone could cause the symptoms I have mentioned.
A wheel speed sensor causes lighting issues? I doubt it, the service trailer brakes and ABS light, sure.
On 5/13/2024 at 5:24 PM, uzurhead said:
service trailer brakes message came on along with ABS light... I plugged in my horse trailer to check everything and the left trailer blinker would not work and then I received messages of service trailer brakes and check trailer connection...
I got a very weak voltage reading on the left blinker so the issue stems from that point forward.  With random messages and funny acting lights...
    overspeed
    overspeed
  • Who's Online   2 Members, 0 Anonymous, 141 Guests (See full list)
