I was having problems with the power running board on the drivers side of my 2020 Denali.
It would start out and then go back in after about an inch. I did some spray lube on the arm attachment points and could get it to work after assisting manually. But after a couple of days it did the same thing.
Googled and found the attached, which has the repairs for this problem and others that are common to the power running boards.
I did the arm removal, cleanup and lube recommendation, which required no parts and took a little over an hour.
This running board works perfect and just as smoothly and fast as the passenger side.
Thanks to the crew that posted this great help source.
https://www.camerasource.com/industry-news/gm-articulating-running-board-repair/
Tri Flow lubricant worked the best for me on my old '11 Tahoe factory power boards. I just would spray the pins/bushings every few weeks or when they seemed to slow down.
The penetrating oil spray was a temporary for me. Even when I’d work them each time, they were still slow.
When I took the arms off, I could see that seals kept much lubrication from reaching the pins. The build up was a weird film-but once fine paper cleaned up and lubed, everything worked like new.
When taking the running boards apart….you should install Zerk fitting in the articulating arms so you can grease the pivot points every oil change….
I have a pair of these boards I took off my 2019 Denali sitting in the garage I would like to get rid of.
909.380.9066
  • 8 months later...
909.380.9066
What did you replace them with and if so are they plug and play?
I had the typical Deploy and stay deployed or not deploying at all. The stealership said it was the motor and wanted $1400 to fix it. I told them I would just replace both hem with better ones for that.
I removed cleaned and lubed the running board and motor and all worked well for several months now nothing.
I read where it could be the module or the switch on the end cap.
