Installed a 12v socket in my 2024 GMC Sierra GMC 2500HD AT4 today. Goal was to connect the 12v socket to the Aux battery. I've been trying to get a 16 gauge wire through the bottom of the firewall feedthrough on the drivers side. I tried a stiff wire, X-Acto knife, long skinny screw driver, etc. I was able to make a small hole and get a piece of 12 gauge house wire through but was a pain getting the other wire to come through the nipple on the inside.
I got a Diablo 1/4" spade bit at Ace and was able to drill a hole big enough to get a 16 gauge wire through by bending the edge over the end of the long skinny screw driver and pushing it through the hole from the engine side. I taped that wire to one of the 12AWG wires and used a drop of oil spread on the tape and pulled it through the firewall. Taped the other 12 AWG wire to the first one and pulled it through.
I used Wirefy connectors with built in heat shrink and an Ancor crimper, got both from Amazon. 12v socket is a Bulldog Winch 12v 20A part number 20286. Bulldog Winch wanted a lot for shipping and got it from etrailer. It's rated for 20A, fused it at the Aux battery with a 15A fuse. Connected the negative wire to the ground bolt for the aux battery on the top of the fender. It comes with 3 different mounting options. I used 12 AWG red and black wiring from a local West Marine along with 3/8" split loom from West Marine. Split loom claims it is self-extinguishing. Secured the 12v socket with Scotch Extremely Strong Fasteners. Not sure how it will work but will probably have to hold on to the socket when connecting anything to it.
See next post for more pics.
Edited by rjgvt
First pic is wires inside the cab from the feedthrough.
Second pic, socket is mounted to the lower dash to the left of the console with the Scotch fastener.
Third pic: I moved the excess wiring/loom away from heat duct output. I tucked the excess in the side panel. I might move it more to the right of the heater duct.
Fourth pic: Wiring in loom from dash feedthrough.
Fifth pic: Wire loom from feedthrough to aux battery.
More pics. I ty-wrapped the wiring/wireloom to the other wiring in the engine compartment away from any liquid carrying hoses.
Last pic is where I mounted it before wiring it.
Just wanted to add that to make it easier to work on the feedthrough from the engine side, I laid a moving blanket across the front of the truck and engine. I used a ladder next to the front of the truck with the blanket protecting the truck. I initially tried working next to the drivers side on a HF step stool and was not able to see what I was doing.
Rerouted the wire loom under the dash to behind the heater duct and tucked the excess in the console panel. Also some finished pics.
Plan is to use the USB socket thing for plugging in my Garmin Inreach Satellite Communicator. My last truck had two 12v sockets, one was always on and used it for charging the Garmin every day or two. I could charge it in camp but would probably forget it so I leave it in the truck during hunting season.
Edited by rjgvt
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
