Im looking at getting the flashpaq by super chips and running the 87 tune and disabling the DFM BS.  Has anyone done this?  I’ll be doing this in a 2020 GMC Sierra 5.3 10 speed.
My main concerns are Illinois emissions and towing.
I’m wondering if I will fail emissions or get a “not ready” status running this tune with DFM disabled?  I’m also wondering if it’s ok to tow with that 87 octane tune.  The one video I watched on it said it’s not for towing for some reason.
Just wondering if anyone else has gone this route and can answer these questions and maybe give me some honest feedback about the flashpaq.  Thanks.
  • 2 months later...
Matt,
I have the Superchips Flashpaq. I ran the 87 tune for one tank, and I will tell you it is not worth it. The tunes will not affect emissions, but if you are considering using it for towing, use the "tow tune" and run the higher octane fuel. The 87 tune will likely not get you the performance you want.
For context: I have a 2021 GMC Sierra AT4 with a 5.3 10 speed. Exceptions - I am running a Fabtech 4" lift, 35x12.5x20 Toyo AT3 tires, Cold Air Inductions CAI, and the Borla S-type exhaust.
Flashpaq bonuses: the button memory is great; it disables all the silly things you don't want a V8 to have. The calibration for tire size is pretty much spot-on. The pedal sensitivity adjustment is enjoyable, but it can decrease fuel economy due to the fun of it all. My "real world" numbers on 93-octane and the performance tune: average of 425 miles to empty on fill up; 17-18.5 mpg by hand and on the computer (400-mile distance calculation), and incredibly fun to drive.
Respectfully,
Doug
49 minutes ago, schwingaling said:
Matt,
Respectfully,
Doug
Appreciate all of this info Doug!  Thank you!
1 hour ago, schwingaling said:
Matt,
Respectfully,
Doug
Hi, so is there a HP/ TQ  gain with this in the performance tune or is it just the throttle sensitivity?
Is the the one that has the "locksmith" to unlock the ECM and the TCM?
The performance tune has a modest HP/TQ gain in addition to the throttle sensitivity. The "performance" tune is more HP than TQ, while the "haul" tune is TQ-focused. The power increase is not as drastic as the numbers you are going to see with the 6.2 (which are the numbers they advertise), but I have no issues with get-up-and-go running a lift and 35s while doing truck things. For the 5.3, it definitely increased the joy of driving and seat-of-the-pants performance.
It is important to note the "performance" tune is not for hauling, but with the ease of switching tunes, it is not a terrible headache to switch when I need to haul something (which is not very often and planned well in advance).
Yeah, you have to send the ECM to the company (Holley is the parent company, I believe) to have it unlocked to work with the handheld flash tuner. It was about a 72-hour turnaround.
My only concern now is whether or not I am able to add a supercharger since another company unlocked the ECM. I am going to send inquiry emails to tech support at Magnuson and Whipple to see if I can use my current ECM or if I need to get a new one for the supercharger tuning.
  • 4 weeks later...
Update: You no longer have to send the ECM to the company for unlocking. They sell the FlashPaq with Locksmith device, which allows you to unlock everything in your garage using the hand tuner and update software via your personal computer. The new system (2849-F) allows you to unlock the TCM previously unavailable on the older FlashPaq tuner for the 19-22 Sierras. This is great because, depending on what tune you used, some of the shift points would be a little off (surge/holding high RPMs when not accelerating).
I have reached out to Superchips to see if there will be a kit/software update for those of us with the older FlashPaq (2847-S) so we can benefit from unlocking the TCM and correcting some of the shift issues.
website: https://www.holley.com/products/tuners_and_programmers/handheld_tuners/superchips_f5_flashpaq/gm_flashpaq_with_locksmith/parts/2849-F
website: https://www.americantrucks.com/superchips-sierra1500-flashpaq-f5-tuner-locksmith-2849-f.html
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
