I have a 2024 1500 with the fancy Android Automotive thing and its frustrating me.  Note I'm referring here to the Google Maps built-in to the truck, not the Android Auto that is used when attaching a phone to the truck via bluetooth/cable.  Today I got in the truck and the little red dot appeared on my name and the message said it was updating the offline maps.  Ok, fine.  I get down the road a bit and notice the speed limit is not displayed on the HUD.  After I did my errand and started the truck again, the map showed a global view.  It would not show my local area.  I could zoom in to my area manually but it will not show my location.  When I click the icon for gas or food or just general search it says waiting for location.  I did choose the option to delete the offline map and re-downloaded -- and that was successful.  I so logged out of my Google account and logged back in -- did not help.  In short, Maps does not know where I am.  Maps was working fine yesterday.
The compass does know what direction I'm heading and the wifi streaming channels of SiriusXM are working.  That leads me to think the communications module is still working.  I say that because last year my previous truck also had and issue where the maps, data (streaming channels and offline maps), compass and myGMC App on my phone all stopped working and the cause was the communications module that failed.
Does anyone have any suggestions what this issue might be or experienced the same?
Don't use the Google map icon. You must be signed in and have an account, pay them. Use Google maps from you're Android
For others that run into this problem, its an easy fix.  In a nutshell, Maps “forgot” it could use my location although the setting said it was ok to use my location.
  • Go to the Settings menu of the truck,  not the Maps settings
  • Select Apps and Permissions
  • Select App Permissions
  • Select Location
  • Select Maps
  • Go to the bottom of the screen and choose Deny.  This is telling the Maps app to not determine your current location.
  • Now select the option Allow All the Time.
That’s it.  At this point I got a message stating it was downloading maps.  Let it finish and then Maps was able to see and track my location and the speed limit on the HUD returned.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 366 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
