I am troubleshooting my 14 sierra ac system so I bought a set of gauges and a vac pump. I hooked them up started truck and turned on ac to high setting and neither high side or low side show a pressure and the compressor didnt kick on but when I hook up cheap gauge on my refrigerant can to the low side the pressure goes up to like 85. Not sure if just got a bad set of gauges and manifold or what
Most connectors on gauge sets require that after you quick connect, you need to turn the screw in portion of the connection that depresses the valve in the port
