I've had my 2023 AT4 with the 6.2 since late August.  I love the no truck and no issues so far except the occasional annoying slow software startup or the a/c fan turning itself down a couple of minutes after starting the truck.  Today after an uneventful drive home from work I park in my garage as usual.  After exiting the truck and walking toward the house I start hearing an unusual noise.  It is a sizzling sound every few seconds.  I start looking under the truck and see water dripping down the driver's side of the transmission pan onto the exhaust line that passes under the pan.  I've never heard or seen that before.  Is it possible my drain from the evaporator is plugged?  I'm guessing it is water from the A/C.  No rain in a few days here and no puddles.  Also, I saw no water dripping in the usual spot passenger side just forward of the cab.  I've attached a picture that shows water collecting on the exhaust line after it cooled down enough to stop cooking it off.  It is hard to see in the picture but appeared to be collecting and dripping onto the exhaust just forward of the pan bolt in the picture.  Has anyone else noticed this?  Also, this is the first time I've climbed under the truck.  That exhaust pipe is rather flat top and bottom.  Is that normal?  I have not hit anything while driving or been off road.  There are no marks on any of the other skid plates, framework, or lower front fascia.IMG_4390.thumb.JPG.fd4cdbb55b4b98c8303829f120eb68c3.JPG
It's been that way since these trucks came out in 2019. There are a few posts about it already. The exhaust pipe is also designed that way on all of these trucks.
Edited by 2016 Sierra Owner
Both normal conditions. A/C drains onto the trans and drips onto the exhaust pipe. Exhaust pipe below truck is semi-flat shaped. Engineers claim this causes no restriction in the exhaust flow. All the newer 1/2 tons are like this.
OK.  Thanks to both of you for the replies.  I guess I just never noticed the sizzling sound before.  And my first thought if that was the normal shape of the exhaust pipe is that would seem to be restrictive.  I'm sure the engineers know better than me.
    jrogjr
    jrogjr
  • Who's Online   1 Member, 0 Anonymous, 336 Guests (See full list)
    • Average Assembly 4.8%   That's the likelihood of a light duty vehicle reaching 250,000 miles. Link below has the stats on this. Among pickups the 350 series (Dodge)  and higher (450 Ford) are most likely and nothing American built in the lighter trucks pegs a number higher than the overall average.  200K and up is the stomping grounds of Asian vehicles. Toyota Sequoia the leader at 39.1% probability.      https://www.autoweek.com/news/a68886903/vehicles-most-likely-to-last-over-250000-miles/   Likelihood drops dramatically at 100,000 miles of reaching even 150,000 miles. 250,000 is deep in the tail of the curve.    I've been told by the 'experts' that I don't need oils of the caliber I use. My high viscosity is damaging my motors. Ash content it to high and WILL foul plugs and kill cats and O2's. I don't need that much ZDP; my choice is over added and not cutting edge. I change it to often. I baby them to much.    Three Honda's reached 200K + and none used oil. All Red Line motors. All sold to friends or family. One Toyota reached 300K using oil, Pennzoil. Dizzy 300K using QSUD until it cashed the rings at 80K then whatever but often ever since. Did you know this engine still sports the OEM timing chain and is dead silent? Pepper spitting into the wind short of 200K, Red Line and changed often. Uses zero oil. A HPFP and a pinion seal. Still using most parts it left Fort Wayne with. So 50% of my vehicles have gone past 250K and 100% of the last half dozen past 200K. Of these two using "shelf oils' did so using abnormal oil and the four that used a premium boutique oil did not. There might be something there the experts have missed. 🤔
    • i dont know where you been reading...they make a top notch product..people say lots of great things about them..yes it can be difficult to get a hold of them when you need help sometimes put when  you do it is great service...   as for the actual question at hand i have the ccv mod and i vented to atmos in my case...I got my ccv from somewhere else but i have plenty of VSE product...for starters i use their tuning on my 22 duramax
    • It's not that it sits for extended periods. I drive it every couple of weeks. However, I did consider draining the DEF and replacing it.    Don't you get a "Poor quality DEF warning" if its bad?
    • Try draining the def and relacing with new if it has been sitting for a long time. Def does go bad after a little while.
    • Thanks @Viktorrocks15 if you are still out there.   I followed your instructions and worked out great, went to the scrap yard and procured 2016 escalade cluster, hud, bezel, and switch. Got lucky and found a Camaro in the u-pull with the HUD bezel.   I made my own harness with these diagrams: https://www.gmupfitter.com/wp-content/uploads/2022/10/23_Escalade_Escalade_ESV_Electrical_Body_Builder_SM_en_US_2022OCT25.pdf   I used escalade cluster because its the best one that will work IMO. Still need to get it programmed but it looks really good.
