First time pulling a trailer with 1/2 ton GMC suv.  When starting to climb rolling hills the GMC starting surging.  The surges were quit noticeable and concerned that the truck to stop but it continued to run while surging and speed reduced.  Once on the top of the grade the surging stopped but engine didn't seem to have the normal power.  The tach did not vary during the surging.  Does the issue sound to be more engine or transmission issues?
How heavy was the trailer? DId you check on the dash to see your transmission temps at all?
Usually the tach would move some if it was surging, because either the engine is being lugged down or the transmission is slipping/torque converter issues.
You could also have a trailer brake be an issue as well. The brake could be dragging and releasing on an incline and that is what you are feeling. Hard to say at this point without driving your truck and see it happen in person.
The trailer is 4800 lbs.  The transmission temps topped out at 248 degrees.  I have been told after getting home that the transmission temperature should not have been over 224 degrees.
I thought that the tach should move some also when surging.
The brakes could possibly be an issue, because the  sensation was similar to what I think the fill would be hitting the hand brake while in motion.  After purchase and before getting on the road we did check the hand brakes to be sure that they were working, and they were.  Is there something on trailer brakes that is activated when not on level roads?  I did read on a post where someone disconnected the cable to the trailer to test the possible brake activation; their results were negative but something I should check.
I will check the brakes and see what the results might be.  Thank you for your response and suggestions.
My son is out of town for about two weeks.  I will post the results of the  after the test.
I only saw that kind of trans fluid temperature and higher while climbing 7-8% grades in Bighorn Mtns in WY. Partially my own fault but that's another story. My 16 Silverado was pulling my loaded toy hauler that weighed somewhere around 6200lbs. Regular rolling hills have never gotten that high.
What kind of controller are you using for the trailer brakes? Is it an OEM built in or an aftermarket? Could be a problem with the controller?
I would say though,that if it was the trailer brakes dragging or locked up, you should at least be able to smell it or see some smoke coming out from behind the wheel(s).
Edited by mikeyk101
Yeah, those transmission temps are way too high. You need to install the lower temp transmission thermostat from GM or do the thermostat mod to stop it from working and have it flow fluid all the time. The thermostat mod will reduce transmission temps under normal driving condition by at least 30-40 degrees.
It can be 80 degrees outside and I'm cruising down the highway with temps in the 140's.
    • While you are waiting on parts...   On my last few vehicles I've been installing full ceramic UVA/UVB/Infrared blocking window tint even over the solar glass my 2015 was fitted with. At high sun angles on cloudless days this is HUGE reduction in compressor load (interior heat from radiation) and your personal comfort. The new generations of Refrigerant are not as efficient as they once were.    I can't see my breath (meat locker style) but I can run the system on very low settings on very hot days and be quite comfortable. It keeps up well and if you use the recirculation until cooled down, it does so fairly quickly. If ultra humid stay in recirc. The blend door has a minimum; you won't suffocate.
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
