What are your goals?  More power?  Better towing?  Big thumping cam?
Edited by newdude
Looking for power/towing more so on torque to move it, Its for a stock 2001 chevy silverado 1500. 3.42 gears. I have HP Tuners, and ready to return when neccessary, but alot of people are steering me or trying to steer me away from the 4.8l the thing is Its basically new, 25k miles and is a great motor, also I dont wanna make a whole lot of power hence why I dont wanna go bigger motor. I want to target around 50 to 100 TQ/HP
Easiest thing would be any supercharger, that is a instant 75+ horsepower and torque on that engine.
The next best options you have are modding the engine. Install a small camshaft, like 212/218 in size. You can mill the cylinder heads a little bit to bump up the compression ratio to gain more power too. I'd stay with the stock exhaust manifold to keep the lower end torque. And a small camshaft will work with the stock torque converter.
You might see a 40-50hp gain at peak with those mods. You'd need to do alot more to really see gains on the 4.8, but then you don't get a useful engine anymore. The peak power will but pushed way out because you'll have to spin the engine to 6,500-7,000rpm.
If the truck is 2WD, for sure swap gear ratio's. I would do 3.90's in a 2WD. If it's 4WD, go with 3.73's or 4.10's because last time I checked you can't get 3.90's for the front diff.
Thanks Best Advice yet. I dont wanna spend $5000 for 75hp for a supercharger doesnt seem fitting to me!
but $500 to $1000 for other mods and 50HP/TQ makes sense to me. plus 300 for tune or so. I have a HP Tuner, so I cant get someone todo the tuning for me!
Can we talk about the gears? I want to know if I can do it myself, can I change just the rack and pinion or do I gotta change it all and how hard is it on Gen 3 Trucks? its 2WD btw
Changing gears isn't that hard, you just need the proper tools to do it.
The ring and pinion is all you have to change, the center section can stay the same if you wanted to. Or you can go with a real posi traction diff, like a eaton tru-trac.
You'll need the ring/pinion set. New bearings and seal, torque wrench, dial indicator and a press would be handy. You can watch tons of youtube video's on it. I bet most driveline shops would charge $1,500 or more to install gears in a rear end, that's parts and labor pricing. But changing gears from those boring 3.42's will make a ton of difference in towing and getting up to speed much faster.
Probably be real easy to find a 3.73 axle with G80 in it, bolt on and go. (Tune update of course.) 4.10 would be just as easy to do but harder to find.
The 4.8 was never a torque producer, power only really exists spinning it fast. I'd select mods to compliment that, a higher revving cam (within reason) wouldn't be a bad choice.
Top end kit, long tube headers, transmission cooler, gear swap, tune. Cam shaft selection would take the most careful thought. Lastly, depending on the cam maybe a torque converter.
For towing, the transmission cooler I'd recommend if your truck doesn't already have it an electric trailer brake controller and good receiver hitch.
Otherwise all the mods ought to make a fun little truck to drive around.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
