I'm having a problem with this truck. Once it gets warmed up and I come to a stop light or stop sign the engine dies. It won't restart unless I wait for 20-30 minutes. Then it restarts fine but will die again unless I put it in neutral and keep the RPM's at about1200 at the next stop. I can get it home that way.
Does anyone know how to raise the idle on a 4.3L Classic throttle body engine or have any other advice for curing this problem?
BTW, it doesn't throw any codes. It just dies.
Edited by thx1138v2
Fuel filter, ignition control module, clogged injectors , vacuum leak are all possibilities. A scan tool that does live data may be needed to determine the fault. Do not try to adjust the idle. Try cleaning the idle air control valve, it may be stuck or if it is running so poorly that it can't raise the idle enough. Look down the venturi on the throttle body and see if both injectors are spraying evenly, shining a timing light on the spray may help you see the pattern. what does the scanner read for coolant and ambient temperature?
It doesn't have a fuel filter. The ignition control module is new and I renewed the temperature grease on the back between the module and the heat sink and the heat sink and the steel bracket.
It runs fine when it runs so that rules out clogged injectors and vacuum leaks. It is a 2007 model so it has OBDII but throws no codes.
Do not try to adjust the idle. OK.
IAC is new so that's not the problem. It is an LU3 engine so I can't see the injectors but it has 6, not 2.
 Coolant temperature shows on interior gauge and is acceptable. Ambient is about 90F but it doesn't matter if I'm driving in early AM or late afternoon, I have the same problem.
I tried to bench test an O2 sensor this morning but couldn't get it above ~375F with my propane bottle. I'll have to get some oxygen for my oxy/acetylene rig.
At this point I'm thinking it is running fine while in open loop but stumbles and dies when I come to a stop and it has switched over to closed loop. I can go a couple of miles but when I come to a stop it dies. If I let it cool off for ~30 minutes or so it will start and run fine until the next time.
Edited by thx1138v2
Added more info
Yeah you need a scan tool that does live data to see what the problem is. The temp gauge and actual outside temp have nothing to do with what the sensors are reporting to the PCM . I would check the fuel pressure AND volume. There is a filter in the tank that may be clogging and then the debris washes off enough to restart
  • 3 weeks later...
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
