next scheuled chat
R Dogg 56
We could havem a tuesday night chat if yall would like. I'm not sure how many people we would get though. I generally like to give people enough time to see the thread when we shedule these things. Hence, the thurs. night chat.
Bump to top, with a comment...
The last few time that I have lurked or posted in the chatroom, it has had a significant increase (as far as I can tell) from members, both from SilveradoSS.com and my fellow GM-TC'ers. It's been great to see everyone there and shoot the breeze, with the occasional mod popping in and saying Hello. The atmosphere is generally clear, with the occasional off topic chat, but that's why chatrooms are here, for our enjoyment, right? :thumbs:
I guess you could say that this is more of an invite than a review of the chatroom, but I've been generally pleased with the content at discussion and responses from those that pop in, and hope to see more of this in the future. So I have an idea, and I'll run it past y'all and let me know what you think: Let's have a scheduled chat at least once a month. And if the mods could post a stickie or something at the top so that anyone who sees it will know when it is, that would be cool.
So to all of those that wanna see what all of this blather is about, pop a :flag:, knock back a :) or three, and talk it up some.
See you there. :lol:
PS: If there is an unscheduled chat that happens, that's ok, but it's probably not necessary to post a thread on the board, because many people won't have time to see it and get in to chat. Just my twocents.gif
(sorry once again for kyping your smilies, Wingnut :lurk::bs: )
yeah guys the chat has been goin good. hope to see you all there.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
