On 2/2/2025 at 1:00 PM, Z45 said:
Simple, Dealer DOES NOT have an allocation to get his order placed.  No allocation, order won't get picked up. Find another dealer and make sure they can order it.
Dealers only receive allocation if earned ...some weeks it is not earned and not available...
so are you saying that they are always building double cabs..reg cabs and extenda cabs all at the same time? why would one dealer not be able to get there orders picked up? more money in gms pocket isnt it?  i dont know how this system works. only one dealer around me so i'm kinda screwed as far as that goes
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
