Has anyone added lights to their multi purpose tailgate which also has the Kicker speaker system?  If you have any chance you have the link to the lights you purchased and can post it here?
Thank you in advance and I wish everyone a very Happy New Year!
Edited by BryanKlingele
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
